- 1 Jan 2006
- Sheffield
... er, I mean Antec Sonata III case.
I've OC'd my E6300 to 2.8ghz with a basic BIOS FSB increase to 400 from 266, and I've got my Geil memory running at stock 800mhz with 4-4-4-12 timings. I don't have the confidence or knowledge to get it all higher, but it's very nippy and stable on my new G33 board and I'm happy to leave it at that
However, I also upgraded from a 7600GT to a 8800GTS, and added a couple of drives in a RAID 0 array, so my mATX case was getting cramped and my ropey Xilence 400w PSU felt seriously underpowered. I did think about going for a P182 with a Seasonic, but ended up being a cheapskate (hey! I'm still trying to pay off the past 3 years upgrading addiction!) and going for the Sonata III, as it has good reviews and the PSU is especially rated for my kind of setup. I also think my little G33 board would look a bit lost in a P182!
Got the Sonata today, had fun building the system as tidily as possible, and set it up with XP. Installed the obligatory Oblivion for my personal benchmarking. All well and good - this mofo flys!
However, I'm getting much higher temperatures than ever before - at idle the system and CPU both hover around the 50c mark, though the GPU is only reporting 64c, which aint bad I guess.
For a cooler I'm currently using a Zalman CNPS8000 Ultra Quiet Low Profile, which in my previous setup span at about 1000rpm and kept my non-OC'd E6300 at about 30-40c. It's now spinning at 2000rpm and having trouble! For case fans I've got the standard Antec Tricool on low blowing out the back, and an Akasa AK-183-L2B Amber Ultra Quiet 120mm Fan held onto the drive bay with rubber widgets - this just about squeezes behind my 8800GTS! I think this is the worst aspect of the Sonata III - it's a very ineffective placement for a fan, blowing hot air from the drives over my system, and barely sucking in any cooler air from the front!
It probably doesnt help matters that I have the system in a hideaway workstation next to my full size desk - its the only place I can put it as otherwise I'd be knocking my legs on it all the time. It does help reduce noise, and it does have an open back with my case back about 2 inches away from the wall, but I guess it is still just circulating the hot air it produces.
I'm thinking of upgrading my CPU cooler, but I'm not sure what might be the best solution. Or what might fit in with my combination of hot things!
I've looked at the Scythe Ninja, and then gawped incredulously at the Titan Amanda, until I saw its price tag.
Any suggestions?
Any suggestions?
