- 26 Jan 2005
- Newcastle, UK
Basically I can't afford a new system at the moment, but I know there is a few bits and pieces I would like to upgrade to scrape a bit of performance from it. Question is, is it worth it.
I'm not a massive hardcore gamer due to lack of time, but I do appreciate having graphics maxed out, or at least looking respectable.
My current system:
- MSI K8N Neo4 Platinum SLi
- A64 3500 Winchester
- 2x512Mb PC3200 OCZ Dual Channel
- 1x nVidia 6800Ultra 256Mb PCI-e (Running 2x 20"W monitors at 1680x1050)
Now, the board supports A64 X2's. So, I was thinking about buying a 2.2GHz X2 for £60 and upgrade the graphics.
I would really like to get my hands on another 6800 Ultra 256, but I can't find any. Another option would be to buy 2 new graphics cards and run them in Sli. Problem is I'm not sure what I should be looking at as availability for older cards is very low.
Will I get any more performance noticeable out of this machine with non-DDR2 memory? Would buying 2x1GB dual channel be something to think about?
Any recommendations on what I should do? I would like to get a bit more life out of the ol' girl before she's scrapped.
Thanks in advance,
Scott
My current system:
Thanks in advance,
Scott
As for graphics, you'll be wanting to avoid SLI as you can't use multiple monitors with it. A single 8800GTS would fit the bill nicely.
