- 18 Oct 2002
- Aranyaprathet, Thailand
Massive Attack said:how hot you ask 52 Idle @ stock its not affecting my system but i want it cooler so i can get a decent overclock i am using everest ultimate to mesure temps, i am using zalman 120mm fans which push 87cfm at full speed and around 40 at slow i have a pic but its not very good
E6600 at stock with that heatsink should be no more than a few degrees above ambient so either
a) your case-cooling is pants
or
b) your temps are wrong
or
c) your heatsink is not mounted properly.
To check your case-cooling what happens if you take the side off and direct a house fan towards (not directly into from a foot or anything stupid) the system. Does your idle temp drop to ambient? If it does you need to look at why your case cooling is so bad. I have an old PC-60 and its ambient temperature in a hot room today is around 32C.
To check you heatsink is mounted properly, take it off and look at the spread of your thermal paste. It should be evenly spread and of even thickness. If not, you have a poor mount and should check the socket area for clearance for your Heatsink and re-mount carefully.
To check your temps try using Intel's TAT or Speedfan or Coretemp or Motherboard Monitor.
Until you have this sorted you are wasting your time. If your starting point is wrong, your whole justification is wrong in which case you could be spending a lot of money for a flawed reason.
By the way, that rear fan is an exhaust isn't it?
