Possible to install Windows through a network?
16 Nov 2002
The Moon
Hi all, got a bit of a problem, got a laptop which has a doofered cd drive in it and i want to reinstall windows on it. Is it possible to hook it up my network at home and then do a windows format/install/setup through that? Or am i going to have to find a big enough pen drive and install via usb?
There's loads of ways to do this, either through a ghost boot disk with network drivers (requires a floppy drive) or if you have a windows server you can do it through RIS (but that's a bit hardcore and require quite a lot of knowledge and a windows server box).
You're main issue is booting the machine without a CDROM or floppy which could be an issue. You'll either need a way to do it via a USB flash drive or a PXE network boot.
Burnsy
Cheers Burnsy, i did find an external floppy drive but that route was shafted when we didnt have any blank floppys. What would be my port of call after formatting via the floppy? I was going to say copy the i386 folder from the cd onto a networked computer then copy that across the network the the laptop and install from that, but i've no idea if i could access the network after its been fully formated :s
Have you already got an os on it? You could just copy the installation files to a remote machine and go into the I386 directory and run winnt32.exe, which will start the install from the distribution server. It's called "Network Install".
Yeh there is an OS already installed, if i do this, will i be able to format the machine too? Or will it just rewrite over everything with a new copy of windows.
No it does not format the drive alough, if you create a PXE environment, where all you would need is a boot floppy (network boot disk) [netbootdisk.com]. And then run winnt.exe from the shared folder it will do the same job, except it will allow you to format.
You could map a network drive and then run the desired executable. Thus you can then format the drive eitha full or quick.
Code:
REM ------ Automatically run setup from the distribuation server ---
net use x: \\SERVER\xpcd\
x:
cd\i386
winnt.exe
Should do the job nicely.
