Right I've tried this all morning now, and it still won't add funds to my US account
So right now I've got £25 sitting in my entropay account but can't seem to spend it.. Does anyone know another virtual CC that actually works?
Well entropay does work but it can be a bit confusing at first, has it been verified ie have you sent all the info they want ( i used email), once you have loaded your account, you have to move it over to the entropay card. You wont be able to load the card with all £25 as it takes 4.5% fee so that will be £23.80 ish.
It sounds the same as mine mate, I've got £20 on a virtual credit card on entropay, after the fee's have been taken off, but when you try to use the virtual credit card on the psn store it says the details are incorrect.
Did you use the same address as the one you made for your US account? Im sure thats what I did.
Bit confused with this mine works fine, just added another $5 this morning so all seems ok, I guess you all have had your'e accounts verified etc. If all else fails use there help desk thing works well, and there normally pretty good at answering your questions.
So this is only for the US store?![]()
Well basically I've got a print off showing my card number, CVV number and expiring date. Then at the top it says mmoney is ready to spend, and at the bottom it tells me I've got £25 to spend :-/
I didn't have to verify anything (apart from through e-mail) or send anything off to them, i.e. passport.
It tells me that my card details aren't valid, soI assume there's an issue with the details the've given me? I just hope I can spend it on the Uk store or I'm going to have to put it back on my debit card which will cost me more money for nothing
Confusing is an understatement...
Ok it may have changed but I had to wait until they had taken a total of £10 out in 2 separate transactions and then tell them what they were to confirm my account. I guess you have done this though, so you added money to your account, transferred it over to you're card (-4.5%). Then with US account when you added a credit card you entered in the card number expiry date and your name set for the US account with the same address. Im going to try and add mine to my Oz account and see if anythings change, that may help.
I didn't have to confirm my account at all, just transfered the money in, and they then added their charge on top, i.e £25 added, cost me £26.14 ish.
The ony thing I'm not sure off is if my account details match those on the PSN store? I can't remember my login details to verify that it either...
II didn't think they check your personal details so assumed they would just take the money![]()
TBH for the sake of 2 days I'd rather wait for it to come to the UK PSN than mess around with the payment methods for the US one.
