Has anyone used them? Specifically the snow foam (I know some people have used some kind of snow foam) and the britewheels(?) stuff?
I don't want to use acidic cleaners on my wheels, and normal car shampoo + brush doesn't seem too effective, and/or gets me covered in black crap splatter from using the brush. I can't seem to avoid that, so as little agitation as possible is desirable.
Also, with the snow foam stuff - IF it's any good for a pre-wash soak thing (or if it's not, can you recommend anything else) does it require the use of a special lance - I have a karcher washer and saw there's a special foamy lance attachment thingy available.
