what temp for c2d ?
I'm not too sure as I don't run an Intel, but my bro's C2D rig (an e6600) overclocked quite a lot just hits over 50ºC! Thats on air with a massive 120mm fan (the YS-Tech jobby).
So if you ask me, your's sounds a bit on the warm side. ;)
That's hot, my e6300 @3Ghz, is running 60 a 61 under full load with TAT, Vcore 1.4.
normally to get 2.8Ghz 1.325v on the cpu should do the trick.
my e6400 @ 3.8ghz was hitting 72°c under water... some are hot, some aren't... i'd be happy enough to run it at 70°c
Try reseating it sounds way too hot for a tuniq tower.
Especially at such a low overclock try with arctic silver
a thin line down the middle but not all the way to the edges
a thin layer spread across the entire surface
a thin layer spread across entire surface and a small blob about half size of grain of rice
right in the center this will help if the cpu or heatsink is concave.
Im on a tuniq currently at 3.2 ghz idle is 25c load is 45-50c max.
On hot days load never goes above 60c.
82!!! Thats above what I'd consider a good temp, if it runs that hot it could serously decrease the lifetime of the cpu.
Doubtful it will decrease the life of the time he keeps the chip unless he runs it for 10+ years and who bloody cares, they're bargain basement chips anyway, cheap as chips (pardon the pun) to replace even if anything did go wrong :p
These are actually rated well over 80C - it will probably start to throttle about 85C and it'll shut itself down as it approaches 100C. That said - it does sound abnormally high for that CPU and cooler. You might look at reseating it?
Im wondering this as well-my E4500 hits just over 70 at stock (albeit with stock cooling, upgrading that soon). Ive heard that the E4500 will be hot due to the 11x multi though-is that right?
EDIT-thats obviously 70 at full load! Its around 30-35 idle.
E6300 SL9SA L625A*** (Lapped) - 1.325vCore Bios - Thermalright Ultra 120 (Lapped) & Sharkoon 120mm 2000
Finally got my temps sorted out, before they were much higher but I have since found out that was due to some of my case fans (exhaust) not working and also the base of the Ultra-120 was extremely *concave*
I haven't got TAT installed at the moment but the temps above are full orthos small FFTs load, I think TAT would be an extra couple of degrees, however I am currently using cheap white thermal goo so I'm sure the temps would be a few degrees better with some AS5 maybe?
I didn't take any pictures but the image below is a reconstruction of what the heatsinks base looked like while I was lapping it, it took a while to get the silver anodised coating off in the centre, no wonder the CPu core was hot as it was hardly making any contact with the HSF.
I did also lap the CPU which wasn't to bad actually, a tiny bit concave but nowhere near as bad as the original Ultra-120.
Lastly, it doesn't matter how good the HSF is, if the case is badly ventilated and overheating there is no way you can keep the CPu cool.
I have a 6320 @ 2.8Ghz with 1.4v running 37c idle and 59c under Orthos.
Big Wayne is right in saying that good case cooling makes a big difference. My cpu temps were higher until I fitted 2 x Akasa Amber 8cm Fans on the side of the case along with the normal 12cm intake & exhaust fans. The temps dropped in the case by more than 8c which will in turn have temp drops on the cpu.
I only have a £20 Akasa 961 sat on the cpu but it seems to do the trick.
The Intel site says 65C MAX for C2D, took me 5secs to get that info. ;)
Thats like a supermarket saying that a bunch of bananas are to eaten by the use by date but their still edible 3 days later :)
Intel will always put a lower thermal spec on their cpu's than it really can take as to put people off from over volting & clocking the frequencies of them.
