I really want a new stereo...
10 Mar 2006
I've got a pair of Mission 701 bookshelf speakers at the moment, rated at about 100watts (at a push) which is powered by a half decent Sony 35wpc amp and half decent Philips CD player.
Nothing is pretty special, though the CD player - despite only being a Philips - is actually pretty good. The speakers got 5/5 in a What Hi-Fi many years ago and the amp was just something I spotted in Richer Sounds. All in all, it was about £400 for the lot about 5/6 years ago.
I want to get a new amp and speakers. I'm not fussed about getting a new CD player as to be honest I rarely use it as I use itunes more than anything.
I've seen some nice NAD amps about, ranging from 50wpc right to 150wpc (powah!), and I'll probably go for one about the 70wpc range but I can't hunt down a decent pair of floorstanding speakers that will do the job properly.
I listen to a lot of rock and electronic music, so they will have to be quite clear sounding but able to pack a punch for bass - particularly when it comes to having people round.
I've spotted there are Mission M35i speakers, which can get for £180ish for a pair - but they seem to cheap, and are quite muddy according to some. They use the same cone for the woofer and mid-range speakers, what's that about?
I've seen some Eltaxs, which I dont really like, and some Kef's - but the ones I've read about seem hard to get any bass out of... I'm a bit confused actually where to go. I think about £300 is my budget for the speakers...
Using the same size cones for bass, and mid isnt really a problem. The internal cabinet design is more important. My speakers use 4 identical drivers 2 for bass, and 2 for mid + a silk dome tweeter, and the sound great. Tannoy DC3000's use a pair of 8 inch drivers one for bass, one for mid. Its not a problem.
However Mission were bought up by IAG, and since then their build quality isnt really what it used to be. Designed in europe but built in the cheapest locations possible generally. Its the same story with Audiolab, and most other IAG brands.
IAG cut the price of the Audiolab designs in half by having them built abroad. But I dont think they are even close to a match for the original UK built products... Hence why the second hand market on 8000 series amps often exceeds the current retail price for new ones.
Speaking of which, I have a Audiolab 8000A of the superior original variety ;) in black if you're interested? Very good amps.
It's a bit old school isn't it? Not that it should matter of course! :)
I was looking at some Monitor Audio BR5's for £360. If I got my act together I would've ordered them today to get them tomorrow, as I'm having a party, but it's too late now and I'll have to settle for the bass of my little Mission's. :(
if you gunna spend more than a ton on speakers go have a listen,bargin for me would be some b+w 602s of egay fetch around 60-70 quid which is a lot of speaker for the money. basically i would go listen to some options as everybody is different.
