I'm unsure why you would revert to 32bit if you've been running 64bit Vista.
If you can get hold of a 64-bit disc you should be able to use your 32-bit key with it.
this is correct. the license-keys are architecture inspecific.
Im pretty sure both versions are on the disk.
Trying to sound clever doesn't work when you use a word that doesn't exist such as "inspecific."
I apologise, I missed a hyphen. Do you want a cookie now?
i think the mistake was that you should have used unspecific.
are there noticable differences between 32 and 64 bit?
Memory limitation of 4GB.
well i guess then it might be an idea to use win7 for my HTPC project. and stick with vista 64 on main pc
well... shhi got a friend to order it for me! he did try to was told its too late.
