I think the cars average looking, nothing particularly special, but I would not say abused off hand. The headrests are utterly gash but you could revert those to stock. Main interior (aside from the aftermarket headrests) is probably individual although I can't check spec at this time, gone midnight. I'd suggest if it's an SMG model to avoid, or at least thoroughly check history. If it's a regular manual thats a bonus. SMG boxes of the early era cars within which this falls (pre 04 register approx) can go wrong, when they do it is will be a very expensive fix.
Good luck viewing. Remember to test EVERYTHING. Push all the buttons, test the abs, traction, pdc, tv and all functions, all electricals, lights, power steering at standstill. Be utterly thorough.
This post is intended to be of assistance to the OP, is non negotiable with any other individual than the OP.
