This.
I'd then clear my mortgage then buy a few houses to let out mortgage free. That way the way I live doesn't suddenly change to the people I know.
Very intelligent.. i'd most likely do the same
This.
I wish this wasn't the first thought of everybody and their dog.This.
You're mixing up the lottery with Fight Club again.
I was actually thinking of something completely different![]()
Not from where I'm sitting, £1m looks much better. The way I look at it is:TLDR: both are actually about equal
Normally they make the numbers on these sort of choices a bit more interesting, i.e. a lot more money if you take it over the longer term.
If you accept the £1m up front, you can take out exactly the same monthly stipend of £10k a month, so you have an identical income. Whatever you were going to do with that £10k (spending, investments, whatever) do EXACTLY the same with the £10k you are taking out from the capital. So it nets off to zero exactly.
Initial capital of £1m.
Capital reduces by £10k every month.
Capital earns say 0.2% interest every month.
Now after 120 months, in both choices you have received £10k in income every month. The difference is, with the £1m option, you are now left with over £100k of capital.
Obviously, it will vary based on interest rates etc, but even a 0.1% monthly gain still leaves you quids in.
I've tried to approach this from an absolute angle, by netting off to zero the monthly payments to prove that £1m is the better option. In reality, there could be far better things to do with the with £1m, but we don't need to talk about them to demonstrate that £1m is clearly the best choice.
I would just take the £1m and then not worry about investing it in houses because I'd go do something fun instead and enjoy the freedom I'd been granted due to not having to log on to work every day and having enough funds to travel
Edit: You're right, I miscalculated the breakeven point. I still think £1m is the best option, but you need a decent investment option.Your example is worse than taking the 10k option. to end up with £0 (ish), after 120 months, withdrawing 10k you need to earn interest of 3.7371% to have 100k left over you will need around 5%
If the interest is less than that (while taking out 10k per month) then its worse.
If you are happy to simply not withdraw anything at all, and stick that into a savings account, you need 2% interest for it to be equal.
So the interest rate needs to be between 2%-3.73% for the sum of 1million to be better than the 10k per month for 10 years, depending how much you withdraw per month.
£1m is just much more flexible. You can take £10k/month but you retain the option to withdraw more if you need to e.g. you may be better off repaying other debts.How many of us are disciplined enough to take the money and not dip into it other than the £10k month? I might be tempted with the £10k a month because of the restraint it places on my behaviour.
