Hello,
I am looking to spend £1,000 on a machine which will be used for encoding video's, gaming and also streaming media to my PS3.
I would like to overclock but i thought as this is the first machine i've built that it would be easier buying the pre clocked setup?
Also, what cooling measures might be worth taking into considering if i'd be running the system at 4ghz. I hear the Corsair H50-1 is a great option?
I've looked at the following components, are these a good choice or is there anything i've missed or worth changing?
i7 bundle including Corsair H50-1 - £600
Sapphire HD 5850 - £229.99
Corsair HX 750W - £117.99
Coolermaster CM-690 II Advanced Dominator Case - £85.99
Samsung F3 1TB - £64.99
Sony Optiarc AD-5240S - £16.99
Arctic Cooling MX-3 - £6.99
Thanks for any advice.
