Are the £40 ones POE and managed?If, as has been pointed out above that there are loads of Cheap £40 2.5gbe switches (and there are just look at STH's recent reviews), then that proves the point. It was a business decision that put the 1Gbe ports there rather than 2.5Gbe / 5Gbe ports.
Can you link me to a £40 Managed 2.5 GbE switch with PoE please?there are loads of Cheap £40 2.5gbe switches
You are still speculating without knowing the facts. I would assume that they didn't put in higher speed ports was that it would have driven the cost of the SE over $500, but no one apart from Ubiquiti themselves would be able to confirm however.It was a business decision that put the 1Gbe ports there rather than 2.5Gbe / 5Gbe ports.
That's not £40.The cheapest managed 2.5Gbe / 10G SFP+ is $119.
Who is saying that they are enterprise grade? Have you seen how much an enterprise router costs?But only having a single high capacity downlink shows that these are not enterprise grade, at all.
Everything and then some. LolIt's £400, what are people expecting?
With zero support or (official) software updates. And you kinda need to know what you’re doing with them. Then there’s the power consumption.I was just looking on eBay for the lulz, and you can actually get a second hand Juniper MX5, or Cisco ASR1000 for like £200-300, some cheap optics off fs.com for £50 - problem solved
(So long as you've got a soundproof box to put it in..)
I was just looking on eBay for the lulz, and you can actually get a second hand Juniper MX5, or Cisco ASR1000 for like £200-300, some cheap optics off fs.com for £50 - problem solved![]()
The UDM SE has POE though?When it comes to Unifi, I think people expect better, and I think they have a right to. They market the UDM as ‘enterprise grade’ which it isn’t. It’s prosumer and SOHO, the sort of one box you can chuck in a branch office if you need secure connectivity, central wifi management and basic CCTV at reasonable quality with minimal management time because you dont have in-house IT etc. or are a home enthusiast who likes the central management. That market isn’t not buying the SE product because it cost £550 rather than £470. Unifi follows the apple mantra when it comes to pricing as people are buying into an ‘it just works’ ecosystem. For that, they they shouldn’t need to worry about the non blocking capacity of an onboard switches uplink on a multi-gig ‘enterprise grade’ router, or why a company famous for its PoE AP’s and trying to break into other PoE areas isn't including PoE on its flagship when the lower end stuff (UDR and DW) does, it’s a blatant missed opportunity that they partially righted with the SE refresh, but it shouldn't have ever needed fixing.
I don’t know exactly what it would cost Ubiquiti not to have screwed the onboard switch up, but I assume it’s way less than the £290 Ubiquiti want for the Pro 8 PoE. That puts a basic non blocking gigabit PoE LAN and multi gigabit WAN set-up with one spare SFP+ port at roughly £855 excluding DAC/fibre/cable/transceiver's. Compare that to the £565 an SE and U6+ cost that any reasonable person would expect to be able to do the same job, and thats why I think Unifi should do better.
You mean just as I said in the remainder of the sentence just after the section you highlighted? Yes, they partially fixed the situation by adding PoE, but ignored the gigabit uplink.The UDM SE has POE though?
It’s a very expensive trap!Id love to see some alternatives then for the same price? That do the same thing.
I have the SE, U6 Pro and U6 Mesh, all covered from the same interface, even I managed to setup VLANS.
I'm about to add a Pro Max 24 POE and some cameras, lights and doorbell.
I don't think that's very fair, there have been loads of gateway improvements since the days of the Pro4. I even moved away from UniFi due to a lack of features, and have since moved back. Multiple WAN, shadow mode, WireGuard server & client, policy based routing, much better site to site VPN support, OSPF (BGP coming soon) to name a few.They do almost nothing more than they did 8 years ago when I first got a USG Pro4.
It's a fair shout, but the point was made by @robj20 was that UniFi is a simple system for people with little networking knowledge to get started with and even do advanced things if they wish. MikroTik requires much more knowledge, the UI is painful, and if you run MikroTik a router/firewall and UniFi switches/AP you have to remember to make network changes in both systems. Many people won't touch full Chinese branded cameras and UniFi represent one of the best subscription free alternates, all while keeping it very wife friendly for things like the Protect app.MikroTik RB5009UPr+S+IN will mince a UDM Pro SE at half the money. It even has PoE ports. And you can get a Dahua DH-NVR-2108-P-I with an 8Tb surveillance hard drive for the other half the money. 4K Dahua TiOC 2 cameras are £120 each, £180 for the TiOC zoom or £220 gets you the TiOC PTZ. And the Dahua WizSense AI in that system makes Protect look like something from the Stone Age. And yes, they do a decent doorbell although there were issues with some Samsung high-end phones not getting alerts. And you can still use the UniFi controller and access points and even the Pro Max switches so the VLANs will still work.
