1 Core dead ?
29 Sep 2004
Mildenhall
hi ive got a core2duo E6600
Ive been away for the weekend (computer was left running) and now it seems that i have no activity from 1 of the cores. Ive run TAT and it shows the speed of both cores but temp of only 1 and also my gadget it vista is only showing the use of 1 core
Is it possible for 1 core to die and the other to keep running or is this motherboard related or Vista related
hohum !!!!
i had done a selective driver boot and that seemed to be the problem
All sorted now
Haha! I have no idea but I find the thought of one core popping its clogs over the weekend quite amusing. I'm clearly hysterical.
Yes you are ...i wasnt laughing !!!! ;)
Hey there,
If you check the windows forum you will see that this is a Vista problem... you might wanna check it out... better news then it being the CPU mate
Stelly
