1 hard drive recognised
8 Feb 2006
Stafford
maybe a noob question
ive just built a system with 2 seagate 320 hard drives
both on a ds4, using the intel controller
in my computer only the c drive shows
where is the other one
same set up on my other identical system, both drives are there?
You'll need to go into Disk Management (right click on My Computer and pick Manage, then Disk Management in the left had pane), the two drives should show up in there, one with the C: drive on it and one empty. Right click on the empty one and create and format a partition on it.
thank you, ive learned something else
