We students do more then that![]()
Students just surfing and mailing?They'll be wanting to download the Internet via BitTorrent or newsgroups, iPlayer / Youtube in HD and the rest...
I think it will be too slow tbh.
Where abouts in Stoke?
Are you actually getting 20mb or just paying for an up-to 20mb service? If its the latter 50mb cable could be a huge improvement. I would go for 100mb cable personally.
Go and get Virgin Media 100mb. Done deal then tbh.
So is it wireless at the moment? Is there cabling in/ethernet ports in the rooms?
A lot of the work might already be done depending on what's there.
Sorry should have phrased that better! Will there be a usage policy, like on campus for example?
Fully appreciate the web is a rich and diverse bandwidth intensive place these days, but if the AUP states no BT/YouTube/smut downloading then it might be feasible to use the option I stated.![]()
Well if you have a distribution cable going to each floor then part of the work is done. To make it a wired you would probably replace those wireless nodes with switches and then run cables to each room.
I propose you look at the project in 2 phases; the internal network which will consist of distribution of networking to each room and the internet connection which you can just plug in to the internal network.
On the internal side you will probably want to get a router that deals with IP addresses and DHCP etc and just have a WAN port which you can just plug any router from whatever ISP you go with.
This way in the future you can change ISP and it wont affect the internal network. The downside of this is that it may require some level of management if it goes wrong, but mainly that will be restart the router.
It may be easier to let the ISPs router deal with DHCP and just plug it into a switch which goes to each floor and then another switch on each floor and then to each room.
We already have something similar to this at the minute, but the internet is too slow when all users are online.
