OK I grabbed a new USB drive (maxtor Basics 1 TB), Ive copied a whole load of stuff over and every on the disk is fine.....
Until I reboot, then when I select the Drive it says "disk needs to be formated", after a moments panic I Unplug the Drive and replug it, Perfect no problems at all.
Reboot again, Same issue.
To get the drive working I need to power or plug the drive after booting up otherwise it says it needs formating.
My other USB drive is working fine (500gb Seagate) so I dont think its a USB issue, only thing even abit strange is that this new drive is flagged as Active in Disk management (TBH I dont even know what that means).
Vista 64bit BTW incase that helps.
If anyone can save me from transfering 700gb of data again then I will be over the moon. Thxs allot.
