10.5.6 is out
I didn't realise that, but good work on getting a profit :)
I couldn't be without mine under the desk, earlier I was transcoding some video, playing a movie, compressing a huge bunch of files, playing Eve, browsing and burning a DVD. 5Gb RAM free and the CPU(s) sitting at 12% :cool: I just love that powerhouse sitting there ticking away quietly to itself.
Is it possible that my iMac is now running much hotter than it was before I updated?
Its crashed once tonight already - can it be a coincidence?
I'm not at all envious :rolleyes:;)
In seriousness though, there were times when I was multitasking like a mo' fo' and I admit, it feels excellent!! but I've been so busy lately that I decided to sell before it became second gen. Bit the proverbial bullet and "Got out while I could" sort of thing.
Back on topic.. full list of updates for 10.5.6.
Mac OS X 10.5.6 build 9G55 Seed Note
Mac OS X Update 10.5.6 is an update to Mac OS X 10.5.
Known Issues
- None.
General Focus Areas
- AccountsPref
- AddressBook
- AFP
- AirPort
- apache
- AppKit
- AppleBacklight
- AppleDictionary
- AppleDisplays
- AppleFWAudio
- AppleGraphicsControl
- AppleGraphicsPowerManagement
- AppleHIDMouse
- AppleHWRaidUtility
- ApplicationFirewall
- AppleWWANSupport
- AutomatorActionsBinaries
- ATS
- Automator
- backupd
- BatteryMonitor
- BezelServices
- Bom
- BomArchiveHelper
- Bluetooth
- BootCache
- Calculator
- CFNetwork
- Chess
- CoreAudio
- CoreFoundation
- CoreGraphics
- CoreMidi
- CoreServices
- CoreTypes
- cups
- DirectoryService
- DiscRecording
- diskdev_cmds
- DiskImages
- Dock
- DVDPlayer
- DVDPlayback
- Finder
- Foundation
- gnutar
- GraphicsDrivers/OpenGL
- HIToolbox
- iCal
- iChat
- ImageCapture
- Installation & Setup
- IOSerialFamily
- IOStorageFamily
- Keyboard & Mouse
- KeychainAccess
- KeychainScripting
- LoginWindow
- Mail
- MobileMe
- Networking
- Network File System
- OpenSSH
- Parental Controls
- PDFKit
- Printing
- Quartzcomposer
- QuartzCore
- RAWCameraSupport
- Safari: HTTP Cookies, HTTP Proxies
- SmartCardServices
- Spaces
- Spotlight Syncing
- System Preferences
- TimeMachine
- TimeZoneData
- udf
- Video Conferencing
- webdavfs
- xnu
Areas of Change
- Safari cookies and expiration time fix
- OpenGL rendering fix
- Fix cursor unresponsiveness after long sleep on some machines
Issues fixed in previous seeds:
- Fixed issue with CFNetServiceGetProtocolSpecificInformation returning invalid CFStringRef
- Improved FileSyncAgent stability on the server
- Fixed printing issues in Rosetta
- Fixed compatibility with Safari and Cookies
- AudioQueueStart() and intermittent pause fix
- Misc graphics corruption fixes
- Fixed issue with DAVKit and error handling code
- Resolved issue with MLTE Controls and data capture
- Fixed issue with Bluetooth Preferences panel
- Fixed issue with MobileMe dotmacsyncclient and error messaging
- Resolved issue with Automatic bookmark syncing and dotmacsyncclient
- Fixed issue with Sync Services and slow sync prompt
- Fixed issue with DVI and display detection
- Issue with Superdrive and eject sound resolved
- Fixed issue with MobileMe pref pane and periodic syncing
- Fixed issue with printing a PDF file from Mail.app
- Resolved issue with LaunchServices and downloading playlists
- Resolved problem with Sync Services and calendar syncing
- Resolved issue with FileSync and FileSyncAgent
- Fixed issue with syslog and duplicate message suppression
- Fixed multitouch issue with Finder
- Resolved issue with USB disconnect warning dialog
- Fixed issue with notified syncs and dotmacsyncclient
- Fixed issue with System Preferences and MobileMe sync tab
- Issue with KeychainAccess and prompting of passwords resolved
- AFP Server no longer caches FPGetSessionToken
- AFP Server now turns off replay cache for non replay clients
- AFP Client now advertises that it supports Replay cache
- Bluetooth and USB in closed lid mode compatibility fix
- FileSyncAgent syncing fix
- HTTP basic authentication with long URL containing username/password fix
- iCalExternalSync - you can now change the record identifier to RootNode
- Misc localization fixes
- Buenos Aires (Argentina) Local Time One Hour time change fix
- Fixed issue with CFNetwork and Content-Disposition file names
- Addressed issue with CoreTypes and certain zip file contents
- Fixed problem with USB OTG Disks and Mass Storage
- Fixed issue with Parental Controls and idle sleep
- Fixed issue with Parental Controls and curfew login
- Fixed issue with iDisk Syncing
- Fixed Calculator issue with Swiss German
- Fixed network server file copying issue
- Addressed issue with AudioQueue and CoreAudio
- Fix to Network Authorization UI
- Fixed issue with AirPort Drivers and “off” setting
- Issue with decoding GIF images and CoreGraphics resolved
- Fixed issue with Mail and authentication of inactive accounts
- Resolved issue with iCal Search and text search
- Fixed issue with iCal Alarms not firing in certain situations
- Problem with Quick Look and CoreGraphics resolved
- Issue with iChat setup assistant fixed
- Fixed issue with firewall configs being reset after upgrading
- Resolved issues with CFURLCookies
- Address books syncing fixes
- AFP server login fixes
- Graphic drivers performance fixes
- New iCal Events and AppleScript applet fix
- Safari and cookies compatibility fixes
- Core Audio and AU component version mismatch fix
- Multiple instances of MatrixReverb in separate threads fix
- Core Audio compressor threshold fix
- Switching default audio device’s output stream is now immediate
- More channels for Core Audio 3D mixer
- Programmatically created (public) aggregate device now plays correctly
- Audio Channel Layouts and Unique ID fix
- Changing the composition of an aggregate device audio dropout fix
- kAudioSubDevicePropertyDriftCompensation property can now be set on an aggregate device
- Renaming aggregate devices now propagate device name changes to all applications
- AudioFileOpenURL memory management fix
- CoreAudio AudioFileWritePackets file creation fix
- audioqueue compatibility fixes
- audio file stream compatibility fixes
- ExtAudioFileCreateNew memory management fix
- ADTS files now supports kAudioFilePropertyPacketSizeUpperBound
- Core Audio performance fixes
- CGDisplayBaseAddress and 64bit binaries compatibility fix
- Command-H and applications hiding fix
- FSCatalogSearch() on 64 bit binary app now returns correct results
- iCalExternalSync floating events and stability fixes
- iCal can now identify VTIMEZONE with a simple offset and no transition dates
- Setting iChat setting to “invisible” via AppleScript now keeps you logged in
- Embed ColorSync Profile” in Image Capture no longer leaves invisible file behind
- Image Capture Architecture performance fixes
- Show(Hide)Window() without Window menu memory management fixes
- Linked binary with NFS shares fix
- Keychain Access: Change Password now works for smart cards
- AppleScript/Keychain Scripting now saves passwords as UTF-8
- pthread operation support fixes
- Access times on FAT32 formatted USB external drive performance fix
- Fixed issue with large file (4gb+) writes to LINUX nfs server when initiated from finder
- NFS export and hostname resolution at startup fix
- copying from a framebuffer object to a texture via glCopyTexSubImage2D fix
- GL_ARB_occlusion_query now works with multiple in-flight queries
- Dealloc method of Cocoa PDE is now called when Print dialog is closed
- Two-Sided Checkbox now follows PPD UIConstraints
- Carbon Printing sheets and window flickering issue fix
- ‘Collated’ can now be set as default in print dialog
- Print sheet now honors first page/last page settings
- PDFView now works with undoManager when its document is set
- Paper sizes and some PPDs compatibility fixes
- AERecord-to-NSDictionary translation now handles ‘usrf’ fields.
- Support for serial smart card readers in pcscd
- SyncServer performance fix
- AppKit recognition of xml-format webarchives
- Latest time zone changes for Brazil, Europe, Argentina, etc
- Uploading of files to more than one webDAV volume at the same time fix
- X11 application gnubg segmentation fix
Install size on my Unibody MBP 15" (from 10.5.5) was 377MB
As I understand it, "Combo" updates are better because they physically replace the old files, whereas the incremental updates only patch the existing files. The downsides are that the combos are larger to download, and usually take a day longer to surface.
Yeah I thinks that's what Apple says. All I know is that on my system (2Ghz Core Duo MacBook) EVERY incremental update broke iSync. Without fail i'd download the incremental update, find iSync broken, smite Apple, download the combo update and everything was fixed.
Then I started getting SUID errors when repairing permissions too. And we're talking loooooots of them. This even happened after I formatted the disk, reinstalled OS X and patched it up using Software Update first thing after bootup.
Thankfully a 668MB file, from Apple's servers, on a 24Mbps connection, takes less than 10mins :p
Is anyone else annoyed they removed the power saver selections when you click on the battery icon? :(
haha :D
Removal of power saver selections annoys me also :( Apple please fix
I didn't know that... I only installed OSX 3 days ago, and all I've installed so far is Logic Pro...
I went from 10.5 to combo 10.5.5, then incremental up to 10.5.6...
I'm tempted to just format again and go straight for the 10.5.6 combo update but I can't be arsed as I've got everything set how I want now...
Sounds like that 10.5.6 is a bit dodgy by all reports.. So I'd expect a 10.5.7 quite quickly..
The Register has an article in this area.
Interesting, mine's fine here. S'pose you're always going to have some work and some not.
If anyone, anywhere has said that about a Microsoft patch/service pack screwing large portions of systems up... I shall eat my non-existent hat!
Face it, Apple just don't know how to update their own OS properly :rolleyes:
No problems here. Updated via incremental update (377MB via slow 2Mbit :rolleyes: )
Then again, I wouldn't know about the disk permissions errors.. I rarely / if ever repair the permissions and haven't had a kernel panic since Tiger 10.4.10.
It's nice having a restore disc with 10.5.5 though :o
Touch wood (oh, I say). I've never had an kernal picnic.
It would be nice if you could get a new disc included with the incremantal updates built in, sometimes when I've done a fresh install using my 10.5 it recalls times I've had to do that with a windows disk then only to download a zillion updates.
Maybe a updated disk image, combined with your serial key to download off Apple would be nice?
Anyhoo, does anyone think we'll see 10.5.7 before SL?
Definitely. I'm shooting for a WWDC release of Snow Leopard (June).
You can just create an entire image of your machine using CCC or SuperDuper or even Disk Utility (don't quote me) and providing you have a storage medium big enough (wink, Drobo, wink) you can just restore from that. Boom, back up to a known "good" image in minutes.
I don't mind so much when the install discs have a recent version, but these days the updates seem to be hefty (400MB) :(
Is everyones Airport running ok on the 10.5.6? I'm on 10.5.4 and had Airport dropping issues when I moved to 10.5.5, just wondering whether its ok for me to upgrade, I guess I don't need to as its running sweet at the moment.
Just to keep you guys up to date..
Installed 10.5.4 thge other day on my ex girlfriends machine to solve her issues with Safari and itunes..
Now working fine.. smooth on old tech too.
I'm pretty impressed by OSX tbh.. thinking about a Mini Mac just to play about with... :)
Thanks for all your help :)
