10.7.3 is up
29 Apr 2004
The South West
WiFi issues have finally been fixed. The update is running like a dog though - anyone having better luck than me?
Thank Christ for that.
I think it might be a good idea to finally Time Machine the new Mac now before I update it.
So my wifi wont randomly turn off?!?!?! Sweet!
Is that a known bug then? My 2008 Macbook has been doing it a lot recently (coincidentally it started the day I got a new router/FTTC) but I figured it was just the old legacy hardware just starting to die on me...
WEll have been running everything for about 30 mins now, and everything seems to be running better so far internet wise. time will tell!
Edit: Spoke toooo soon! Still having the same internet issues here!
Hmmm ... had a look and it wants to download 730MB for the 10.7.3 update plus another ~10MB or so for the Airport update. In the five minutes before leaving for work that's not going to happen so it'll have to wait till later for me (by which time there should be some victims who have reported on whether it screws anything else up)
Thanks for the heads up!
Downloading. Won't be anal, will just get the delta.
EDIT - Has it been pulled?
Can't find the combo and software update doesn't find it.
I would quite like them to fix the fact that my Bluetooth drops out every now and again and requires a restart... Good job I keep a wired mouse for backup purposes.
Installed it on one of my Mac Mini's earlier ... had a few issues connecting to the machine via LogMeIn afterwards (cleared after a further reboot) and it had randomly forgotten the password to mount drives off ones of the NASes (but not the other)
Not really done anything with it so can't say if I'm getting any further issues.
Still not installed it. Foolishly asked Time Machine to encrypt the backup. The 2TB FW800 drive is still encrypting 24 hours later!
Update breaks compatibility with many USB audio devices; have had to use Multibeast (intended for those installing osx on generic PCs) in order to rollback the Apple HDA audio ktext. not happy.
