£1000 build help
31 May 2012
As per title I need help with a full build for £1000 including windows but not monitor and peripherals. The machine will be used for 1080p gaming and as an occasional workstation (not video rendering). If anyone can be bothered doing a spec I'd be very grateful. Edit: only needs a 240GB ish SSD, not a regular HDD and probably doesn't require an i7, i5 is fine if it means more budget for better graphics card.
Also, how do I post a spec from my basket as I've seen other people do?
Wow, thanks CEUOTC. This is what I came up with (without windows yet as undecided on which). Also thanks for the link Space Monkey.
YOUR BASKET
1 x Sapphire Radeon R9 280X Dual-X OC 3072MB GDDR5 PCI-Express Card £239.99
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £167.99
1 x Kingston HyperX Blu 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (KHX1600C10D3B1K2/16G) £109.99
1 x Kingston HyperX 3K SSD 240GB 2.5" SATA 6Gb/s Solid State Drive (SH103S3/240G) £97.94
1 x Gigabyte Z97M-D3H Intel Z97 (Socket 1150) DDR3 Micro ATX Motherboard £82.99
1 x Corsair Hydro H80i High Performance Liquid CPU Cooler £74.99
1 x BitFenix Prodigy M MATX Cube Case - Midnight Black £74.95
1 x EVGA SuperNova NEX 650W '80 Plus Gold' Modular Power Supply £69.95
1 x Samsung SH-224DB/BEBE 24x DVD±RW SATA ReWriter (Black) - OEM £17.99
Total : £951.78 (includes shipping : £12.50).
seems underpowered by comparison to a i7+R290 build!
What would you do for a M-ATX build?
