1000W+ PSUs, Superflower or EVGA the best?
17 Jan 2007
Kent, UK
Hi all, just a quick question. I'll probably be upgrading my psu soon and want to make sure I'm definitely covered for whatever gpu's I end up getting (up to possibly tri-fire 290x) so I want go for something pretty meaty. In the 1000w+ area are Superflower and EVGA pretty much the best choices for quality or are there any others I should be considering?
Many Thanks,
Ross
They are both great units, they are actually the same, all bar the lighting.
I would like to suggest adding this to the mix.
YOUR BASKET
1 x Antec High Current Pro 1000W '80 Plus Platinum' Modular Power Supply £199.99
Total : £209.59 (includes shipping : £8.00).
This even has a OC Link cable/connection, allowing you to daisy chain two HCP PSUs together if you would need more power, most people wont, but its an extra feature.
Few uid more, but is made by Delta Electronics who are the biggest and best PSU manufacturer out there, they typically provide some of the biggest server and data centres in the world with PSU's because they are known to be the best of the best when it comes to quality and reliability.
Yeah I'm leaning towards the EVGA ones for those exact reasons myself.
It will be going in the machine in my sig but only when I also upgrade the gpus. My current psu is a good few years old now and wasn't a very good model even when it was new so I want something decent when putting more strain on it. I think the 1000w will probably be more than enough but then it's only an extra £10 to upgrade to the 1300. Are there any particular downsides to running a well over specced psu?
Yeah most likely worst case will be a pair of 290x's but a very outside chance of going trifire 290x. Only reason I really considered the 1300w is that if I'm going to spend £140 anyway then I might as well spend the extra tenner to get 30% more power :)
I went with the 1000w Evga because it is value for money, could have gotten less but the 10 year warranty made it for me although I forgot to sign up to EVGA and only got 3 year warranty :/ If going crossfire R9 290 1300w would be good if it doesn't cost to much more, add another later or overclock like hell it is up to you with no restraints.
:D
Ok well the Black Friday deals made my mind up for me in the end. I've gone for an 850w Superflower and a nice Gigabyte 295x2 to go with it. Should be plenty of power for that and I doubt I'll need to be going tri-fire any time soon now :)
