- 7 Mar 2005
- Eating PI
This is something that has only come to my attention recently but there are many people claiming that moving up from a 60hz to 120hz or 144hz makes an enormous difference in games, especially their ability to aim.
I understand how it all works, i.e. if your gfx card is giving you 120fps on average in a game and your monitor is only 60hz, then you are overworking your gfx card for no reason and setting the game to work at a fixed fps of 60 will correct the tearing and work together with the monitor. Which is basically what Gsync/Freesync do.
I haven't tried one yet but I can't help but think that it's a complete exaggeration that getting a higher frame-rate with a monitor that can display it instantly makes you better at gaming which is what a lot of these sites and reviews are claiming.
I could be completely wrong myself, not having tried one but gaming at 60fps seems perfectly fine and smooth to me and although I understand my eye would notice the difference when moving to 120fps/120hz or higher I find it difficult to believe that my hand-eye co-ordination would be affected at all...
Can anyone help/advise what they have personally found or seen when upgrading to 120hz or higher?
