103424K vs 1024K offset
1 Mar 2010
Tending to be right.
I have noticed many SSD tests with 1024K offset and very few with 103424K.
The latter is with the 100MB system partition which windows 7 installs in front of the boot drive ie 100 x 1024 = 102400K + 1024K. Total offset = 103424K
Does this mean most testing is done without windows on the drive?
I am interested if this gives an unrealistic or optimistic speed test. Please comment.
I found this through google.
On my old P45 motherboard it shows 103424K on the 'new' P55 board it shows 1024k and speeds are about half for read and write
Vista does a 1024K offset, but doubt that many people are using it.
Can W7 be installed without recovery partition thingy, thus defaulting to 1024K?
I think that's what it is. I thought it automatically creates one if you remove it when installing windows 7. I removed it and installed like i normally do but its not there.
Does it matter?
What do you mean for testing should not matter?
I'm running my machine like this all the time now, not just testing
I think he means that whatever the offset is as long as it is a multiple of 1024K, the test results should be the same. In answer to my first post.
