105 5800 Brake Adjustment
12 Sep 2005
Norwich, England
Morning all,
Just back from a ride in the sun and bike wash and I noticed my rear brake had been rubbing on the tire slightly.
Is there anyway to adjust the drop at all? I got a 2nd hand set off ebay, standard clearance I think but the pads are right at the bottom of the slot and it's not quite enough :(
Suggestions would be great!
Thank you
what about if I just filed the slot out 2/3mm.......
The bike is a GT GTS Expert, it came with standard tekro dual pivot, slightly longer i guess :(
Takes mudgaurds so I guess that's why frame needs 57mm?
mudguards are exactly why it requires a longer caliper.
you might get away with filing 1mm, but i'd be sketchy about going any further
