1080p LCD as PC monitor
20 Mar 2006
I know this sort of thing has been asked a couple of times, I'm just in need of a bit of confirmation...
Looking to get a 37-42" LCD TV for my lounge to use as my primary PC monitor - I was planning to get a Dell 24" but then I thought how much more awesome it would be to game and watch movies on a massive TV. Been looking at the Samsung LE40M87BD 40" and think it is probably the one for me, sitting nicely just under the big 1k price point.
A few questions -
I'm fairly confident my 7900gtx will be able to power most games at the native rez, and will be getting a G92 when they come out, but I'm not 100% if my current card will actually allow me to connect to a LCD TV - How would I go about it, assuming it can?
Second, I assume if I 'acquire' 1080p source material, I can play it straight off my PC and it will look great...but how will my current media consisting of a lot of average quality avis look?
Third, I did have a 8/12ms (some confusion there) tft at one point and while my current Hyundai N91W is much better for it, I was content with it for gaming and video media - will the 8ms response on most of the TVs I've looked at be adequate?
Fourthly, would anyone strongly recommend a different tv to the samsung?
Before anyone tells me I'm wasting my money on 1080p, the main reason for the extra resolution is so I can game at that rez on such a large TV, not because I reckon 1080p will look that much better than 720p (haven't seen true 1080p in action yet).
EDIT - I will still have my hyundai monitor in the house, probably as the monitor for the family PC, so I have something to take to LANS, and have a hyundai IQ crt if I'm FPSing competitively enough. Sound quality isn't an issue as I run an ad-hoc 7.1 system off my x-fi xtrememusic.
You need an 8800GTX and or SLI really to power 1080P smoothly.
My 7800GTX512 struggles @ 1920x1200 on a Dell 2405 WS TFT. 7900GTX is only a few % faster so will be the same. Recent games need a lot of GPU & CPU power.
You can connect to a HDTV via VGA to VGA, DVI to VGA or a DVI to HDMI cable.
If you consider a 720P HDTV instead then you only have to power 1366x768 which is approx 50% less pixels to render. I recently bought an 8800GTX and this provides very smooth FPS with full gfx details but that is mainly because 1366x768 is not as many to render.
1366x768=1049088 pixels
1920x1080=2073600 pixels
My Samsung HDTV even though it is only 720P does the lot, X360,PS3,PC & HDMI Upscaling DVD player all have stunning pictures even bluray @ 720P via the PS3 is amazing. 1080P is better but obviously you need a lot more GPU & CPU power as well as a hefty PSU so the cost difference is approx £2-300 more for the HDTV + another £600-1000 for the high end PC components (unless you already have them). 7900GTX will really struggle in recent games @ 1080P with full gfx + AA which are a must on a large HDTV as it is even more obvious when AA is missing.
7900GTX will manage on a 720P set but you will still have to turn down the AA on some titles & or disable vsync but again the problem is that it is very obvious on a larger screen. Do not worry about ghosting/screen lag especially on the Samsung HDTVs as it is not an issue on recent sets.
I would highly recommend my set and guarantee you will not be disappointed:
http://www.overclockers.co.uk/showproduct.php?prodid=AV-035-SA&groupid=703&catid=511&subcat=
I currently have my samsung M86 running through my 7900GS, I only use it to play DVD's which it does stunningly.
Connected via DVI-HDMI cable.
KaHn
AWPC - appreciate the advice, however, since my rig runs every game I play at max at 1440x900 (only thing I found that makes it struggle in heavy moments is Q4 on ultra and COH at max everything) and that I'm getting mobo/cpu/memory upgrade this summer and almost certainly a new GFX by xmas, added to the fact I still have a nice 19" widescreen tft and 17" crt to game on if necessary, I'm happy to pay the extra for a bit of future-proofing. Going water along with the upgrades too, so should be able to OC the 7900gtx. 1900x1200 is also a bit more intensive than 1900x1080.
EDIT - I see you have Altec Lansing 2.1 - I'm thinking of getting a new 2.1 for centre/sub channel asmy logitech set is rather budget - would you recommend?
Anyone know if you can play games on a LCD TV in non-native rez? If so how does that work and look?
I have the same set.
SD AVI's look very good indeed, once you go to 350MB for a 45 minute episode, it'll have great picture with minimal blocking.
You connect it DVI-HDMI. You can use non native, and let driver/display stretch to full screen. If you choose something like 1680x1050 and stretch it, it should look fine.
My pc in sig played Oblivion on a 1920x1080 outside with decent framerate, hardly any framerate difference between 1680x1050.
Cheers - I tend to grab the 700mb 45 min ones unless im in a rush to see it, so should be good.
Mine, but i had a small problem with underscanning, its now fixed due to setting the screen to PC mode,will post more pictures tonight maybe.
KaHn
