50cm is far to close to a 37" screen.
1080P isn't wasted on a 32" because when being used on a PC 1360x768 stretched to a 32" will look pretty eerie.IMHO, 40" is maybe a bit too big for continuous daily use. 32" seem reasonable to me. Are you going to use it as an HD TV as well though? 1080p on a 32" is arguably wasted.
You can't if the video card isn't HDCP compliant (I think). Maybe that's what he means.you can watch blurays and hd-dvd's using vga, dvi or hdmi![]()
What I~ meant was form an HD movie point of view. If you are going to watch HDS films on the TV you are going to sit further back than 50 cm away (hopefully). What I was saying was that at 5+ feet 1080p on a 32" will not look any better than 720p. Certainly it will look good for a PC.1080P isn't wasted on a 32" because when being used on a PC 1360x768 stretched to a 32" will look pretty eerie.
I find it fine, I'm more than used to it. Obviously I sit back for TV shows and movies, just for gaming and general usage I'm up close.
Quote:
a 37" is about 32" wide i think, so its just over.
