1080ti recommendations for approx £700
16 Jul 2010
Anyone got any recommendations for the best 1080ti for around £700?
I'm not really interested in overclocking or watercooling, just want a reasonably quiet, cool, powerful card to replace my 980ti for VR, mainly for multisampling to improve the image quality.
I picked up a EVGA 1080 Ti SC black edition recently and they can be had for just under £700 at the 'tropical rainforest'
@Patberts19 nvidia boost will use the extra thermal headroom available on aftermarket cards, so yes, there may be a performance difference in favour of aftermarket cards.
however it also depends on the silicon lottery
Right but I'm guessing no difference in performance?
With the 1080ti being a powerful card it takes a good cooler to keep it cool and if you can keep them cool they will boost higher clocks, so the better coolers are faster.
With lower end cards like 1060/1070/1080 the cooler doesn't make as much difference as they are easier to cool.
I can get mine to 2000mhz without issue sits around 74c with stock cooler, should do better when I get the so block on. The out of the box oc is good aswell.
