120.2 for cpu and gfx
21 Oct 2002
UK
Hi Folks,
Would a 120.2 be good enough to cool a cpu and a gfx? I am thinking along the lines of the thicker rads like the thermochills.
One the same lines as above. I am thinking about just using the 120.2 for the cpu and potentially getting a 120.1 on it's own loop for the gfx card. Would this work?
Also, for a single loop (120.2 and cpu only) what pump would you recommend?
EDIT: Ooops this was meant to be in Overclocking can it be moved, thanks!
I would say get a 120.2 Thermochill for both gpu and cpu. Its not unless you have a crossfire or SLI system that you really need to worry about adding more rads.
