I'm after some quiet case fan's, because I'm fed up of the noise.
Can you actually get silent fans that do equal airflow to the normal ones?
33dB is regarded as quiet, something like the equilivent of your bedroom at nite time
Very pressure incapable design and specs are BS like usual.Thinking about going for the Noctua's, at £16 a pop...
Actually moving/pushing air makes always noise.Can you actually get silent fans that do equal airflow to the normal ones?
