- 12 Mar 2017
- West Midlands
Hi Guys,
I was just wandering if anyone else has come across this issue and if there is anything I could try?
no display, no mobo beep and all fans spin at high speed
The issue started after noticing the time and date was incorrect in the bios so I updated it and saved. When pc restarted I got the above issue
I’ve carried out the following Troubleshooting steps to try and fix the issue;
Cmos jumper reset, cmos battery removed, cmos mercury reset
Mobo Speaker plugged in
Gpu removed and tested
Ram removed and tested
Removed M.2 drives
Tested different psu
Plugged cpu fans into mobo instead of Corsair manual setup
motherboard sent to ocuk for RMA and has come back as all working
I’ve dropped my specs below;
I7 12700KF
ASUS Z690 Prime-P
Kingston fury beast 16gb 5200mhz
2070 super msi gaming x
Corsair h100i
Factual design meshify 2 compact
2x Samsung m.2 nvme
Cheers in advance I’m currently scratching my head on this issue
Rob
Removed M.2 drives
I7 12700KF
ASUS Z690 Prime-P
Corsair h100i
2x Samsung m.2 nvme
Rob
, but I've tested the following components are all good by building my old system back in;
