13900K HOT, help me, im spanish.
Fabulous with those changes and the negative offset.
Thank you very much, on Monday I will change the thermal paste hoping to improve a few degrees.
Thankssss!!
Fabuloso con esos cambios y el offset en negativo.
Muchas gracias, el lunes le cambio la pasta térmica esperando mejorar algún que otro grado.
Graciassss!!
The temperature of the pump liquid... what is the maximum?, what are the normal values?..., about the data of DC LL and AC LL... are they stable for my 13900k with the Maximus Hero?. ..; Thank you!
La temperatura del líquido de la bomba... cuál es el máximo?, cuáles son los valores normales?..., sobre los datos de DC LL y el AC LL... son estables para mi 13900k con la Maximus Hero?...; gracias!
It would throttle around 100. Every chip will be different due to the chip and other environmental factors. Run the stability test from cb23 and you will be able to see for yourself.
With cinebench23 the temperatures go well, when I pass an OCCT they go more to 90 in a few seconds...
Con cinebench23 va bien de temperaturas, cuando le paso un OCCT se ponen a 90 y pico en pocos segundos...
Un saludo
Un saludo
That’s because it’s putting stress on the CPU, which you won’t see while gaming etc. Try gaming on a few different games and see what temps you are getting.
If it ain't throttling you are winning. You can add or change fans. Bearing in mind more fan speed equals noise. You have to find the right balance yourself. Just enjoy the thing at this stage
The maximum temp for the pump liquid, what would it be?
La temp máxima para el líquido de la bomba, cuál sería?
The normal range is 35-40 depending what you are using the system for.
