Hi,
As some of you may remember from my thread, I recently bought and returned a 295x2 from the OCUK b-grade section (it didnt work
At £400 I thought this was a pretty good deal and for the 1 hour that it worked I was blown away by the performance.
Since it was broken and I had to return it, and with it being clearance stock they couldn't exchange for another one - so I'm sat here with the £400 not really knowing what to do.
I game at 2560x1440 and really prefer to be able to turn everything up to the max settings. Obviously with the 295x2 I could do this.
£400 is probably my limit as far as budget goes. I could stretch to £500 and start looking into FuryX and 980ti territory, but I really don't want to (unless I have to) if I'm honest. I need to draw the line somewhere.
The only problem is that I can't seem to find anything to fill my needs at this butget. Maybe I'm being too picky and wanting 295x2 performance for £400. Now that I've had a taste I want more
lol
I did look at buying a 295x2 new to be honest at £515. But after trying Witcher 3 and jumping through a bunch of hoops and still seeing some flickering textures I'm not sure that I want go down that road. The R9 390 seems like a nice little card (and cheap) but I'm not sure that its got the grunt for 1440p, and the 390x doesn't seem worth the premium over the 390!
The GTX980 maybe?...I don't know.
I don't think buying another 7970 and cross-firing is an option with the 2nd slot on my board only being 4x. Maybe worth a punt though?
Long story short. I clearly need help
Thanks!
).At £400 I thought this was a pretty good deal and for the 1 hour that it worked I was blown away by the performance.
lolI did look at buying a 295x2 new to be honest at £515. But after trying Witcher 3 and jumping through a bunch of hoops and still seeing some flickering textures I'm not sure that I want go down that road. The R9 390 seems like a nice little card (and cheap) but I'm not sure that its got the grunt for 1440p, and the 390x doesn't seem worth the premium over the 390!
Thanks!
