- 27 Apr 2014
Well I do play PC Games only and it is 99% of the time at 4K Max setting on every CPU/GPU combination I use.So 99% GPU bound. I only expect and want equal performance when buying new PC Gear.
PC Gaming rigs I built for personal use since Oct 21 10850K/12600K/12900K/13700KF/14600K/14900KF/AMD7700X all in truth gave around same FPS on GPU's RTX3070ti/3080/3090/4080/4090
14900Kf/14600K are a couple FPS behind in PC Games I tested over 13th Gen and I can not figure out why and I am thinking immature ASUS BIOS problem.
Also, test I have done because on mostly GPU bound in PC Games CPU Clock speed made no difference.Turned Ram speed make no difference beyond DDR5 5600 up to my testing 7400Mhz at 4K also.
So for me the same PC two weeks ago I removed 13700KF and dropped in 14900Kf. Tested some PC Games and the 13700KF was faster by a couple FPS at 4K over the 14900KF.Now to be clear I had the same problem switching from lets say 12600K to 13700KF where the 12600K had a couple more FPS and the AMD7700x had a couple more FPS over 13700KF.
Again I chocked it up to BIOS not mature enough.
There is no real performance difference for me in my use case running 4K PC gaming and CPU clock speed and tuned ram make no real difference.
The more CPUs Intel release the hotter and more wild they get when running full work loads where one needs actual full custom loop for production work if overclocking.
For fun running Cinebench and did not crash but I had it set to downclock on 360 AIO and bump temp limit up to 115
