ca9phoenix said:no hard drive and a wired controler instead if a wireless one. and your cd draw will be white not silver
Kreeeee said:You'll need to buy a memory card to save games.
Online play is perfectly fine with the core![]()
GarethDW said:Can the hard drive be added, like the Hi-Def Drive?
Mr_White said:You won't be able to play Xbox 1 games.
Like a stealth ninja polar bearSweetloaf said:Cheers, you posted while I was looking the other way![]()
When the res is set to 640*480 all of my "non VGA compatible" games work fine.Geffen said:not all game supported and a lot of games not working with the VGA cable.
HTMLHugo said:i saw a premium at a wholesalers today for 200 + vat
is this the going rate nowadays ?
I think a lot of game use the HD to cache stuff, so things like Oblivion probably would result in longer loading ??Sweetloaf said:Yes cheers, I realise thatI meant what limitations, as far as gaming goes, does not having a hard drive create.
