1800 xt problem.....
18 Jan 2004
it seems to be very hot 80c in ati tool and the fans are going mental. it idles at 70c!
Is this normal?
Cheers
Puck
could be your case layout?
cables... wires...?
have you got chasis fans in there?
keeping the whole area over your mobo/gfx/cpu clear makes a difference, and not blocking the front chasis fan so it gets air in and out through the back.
just boring stuff like that can make a difference.. maybe you have done that though
no its not o/c, ive put it in the second SLI slot because it would not fit. didnt realise how big the card was.
Sorry being thick
Temperature of voltage regulator is 80c ( does this normally go up this high?)
the gpu is idling at 50:)
