Worth it for gaming? I found myself to play lots of pubg and destiny 2 as well as escape from tarkov type games with a 144hz 1440p monitor. Would it be worth it for me to do the upgrade or is it a waste of money?
For high FPS gaming yes, more so if you OC it.
Which is exactly what he’s after so big yes really, 144hz will be better and sell the Old it’s a fairly low cost swap in my book![]()
at stock pubg the 8700k is 20 fps better off at same settings.ocd that will increase.so 30/40 fps better with a high oc.
https://www.techspot.com/article/1532-pubg-cpu-benchmarks/
ryzen are not great for pubg.you want a intel cpu and nvidia card.nvidia work with pubg.
I agree. PUBG isn't well optimised and the utilisation on the 6 core and up Ryzen processors is only around 30% according to the hardware unboxed video whereas the utilisation on the 8700K is 49% which would make a significant difference. This is due to shoddy programming though.Pointless if you have gsync/freesync.
And what games are going to hit anything close 144 FPS with a 1080Ti or be CPU limited by an overclocked 1800X? CSGO at 640x480?
1800x is not a bad CPU so let’s not make it an argument about that.
I agree. I would not have sold my Ryzen cpu if I had something other than my 1080ti and a 165Hz monitor.
I did forget to mention that I saw a big increase of approximately 40+fps in Destiny 2 public events. Minimum would drop to 50+ fps with Ryzen while the 8700k would be 90 fps. Destiny doesn't use the smt very well on Ryzen or Intel if I remember correctly.
Those games that we have mentioned are games we have personally seen the differences in and not in just some youtube videos. Nobody is putting down the Ryzen processors. We wouldn't have bought them if they were rubbish but for a certain scenario intel is needed.Thanks for reiterating this. If aiming for 144hz+ then the 8700k is the better choice.
Just as @Smffy said, my 1700 would spaz out every now and again for no reason. Project cars 2 was also a game where I saw decent gains, particularly in multiplayer.
Also I would like to address the freesync and g-sync statement claiming that it wouldn't really matter. It certainly does matter. There is a slight blurring like motion blur that is noticeable at lower fps even while using these sync technologies. 70 fps with g-sync is not the same as 144 fps also with g-sync in fast motion games.
You still want the highest fps possible even with sync tech.
