Deleted User 298457
Deleted User 298457
Hi folks,
Me again. Priorities have shifted around a bit as we debate Part 7 (knocking the wall through into the living room). So focus has shifted to making a nice entrance way, as the new doors have been ordered (5-6 weeks they reckon).
I've had to take up some of the boards for the radiators to be fitted, and they essentially disintegrated. So I knew it'd be a task to get any more up without breaking them, but the plan is to PIR the lot, so up they must come!
I thought a good interim step would be to swap what boards I have with 18mm - first fix, so that I can happily get under them. Floor is likely to be the very last thing as I want the same wood floor throughout the entire downstairs.
Issue 1:
- An air brick that is skirting board height lol..
Issue 2
- And are these boards rotten?
Issue 3 (SOLVED?)
- A while back I posted about a damp issue on the wall. It looks like the wood frame around the door is leaching moisture in. I've taken the plaster off so high, and the wall paper basically came off with limited force. Annoying but luckily the plaster is good... I am suspicious as to why
(not my foot I swear)
Issue 4 (Whoever did this needed to put a Lotto ticket on, stat [the nail top right, not my precision cut])
N.b. track saw is god tier. No way I could have cut that board without hitting that gas pipe.
Fin, for today:
Plan is to:
* Get a vent brick duct so I can block the gap behind the skirting
* Strip all of the paper, at least in the downstairs section
* Sand the stairs
Luckily the 18mm board is spot on level with the majority of the old boards, however a couple of the joists are badly twisted. I think I'll have to untwist them to get a perfect level. Tips?
Edit: here is a before picture:
Issue 1:
Issue 2
Issue 3 (SOLVED?)
Fin, for today:
Plan is to:
* Sand the stairs
