1950 pro quieter fan
Ish
Ish
11 Jan 2006
West Midlands
Hi All
I have just got a Gecube ATI 1950 Pro 512mb but the fan is too loud. What quieter alternatives are there?
Is THIS suitable? The AC website you have to buy an additonal 'voltage regulator heat spreader module' but is this really necessary?
Thanks.
The Zalman looks a better option as there isno messing with a heat spreader etc like the AC.
Does it definatley fit the 1950 pro as when you look on the ZALMAN website it doen't list the 1950 pro in the fitment list?
