Hi,
My friend has a 1993 polo which was fine when he purchased it but now it refuses to start. He had the mechanic who I had come over today to have a look and it started straight away
However, it now refuses to start again. It will turn over without starting for say ten seconds. If you release the key and go to turn it over again all the dash lights go out and nothing. If you wait another few seconds it will turn over again (battery isn't flat)
Do these cars have some sort of auto choke or similar as a K reg fiesta I had would flood itself occasionally and pulling the fuse and cranking it would clear the fuel. Pop the fuse back in and away you went again.
We are confused as to what it could be! Any help appreciated
(car is spi btw)
(car is spi btw)
