1Gb 16 chip query
18 Oct 2002
Cambs
I just bought a new Asus A8N-SLi Premium and 4400x2 together with 4 1Gb OCUK Value ram sticks. Now from reading the manual for the mobo it says it doesn't support 16 chip ie 8 chip dual sided DDR sticks. Which the Value ram is :(
I haven't tried it yet but is this a guaranteed no go? If so I won't open the other pair of modules and will just send them directly back to ocuk. I went for the value stuff as I have no intention of clocking this machine so didn't need anything fancy. I also note that very few of the sales descriptions on OCUk actually specify how many chips are on the module???
p.s If you think I'm being a little greedy with 4Gb, it's because I want to run XP64 and use this machine for Development work, and things like Visual Studio 2005 are real memory munchers.
Odd.... might have been worthwhile to get the OCZ 4GB dual channel 2x2GB kit though (~£300). I should think it would work - I would have thought it depended more on the on die memory controller rather than the board itself which should be the same as any other nF4 board. I mean, people run dual channel 2GB kits on this forum with that RAM so I see no problem tbh.
Ok m8, I will try it with 2Gb first using the ram I have opened. The manual said that it was due to the cpu not the motherboard. Was this a problem with earlier x64 chips that may now have been corrected?
Hmm, might have been. How long ago was that manual produced?
One thing - IIRC, the older x64's like the Winchester and NewCastle could not run 4 sticks @ 400mhz 1T, instead running at 333Mhz 2T. The new revision cores can run 4 sticks @ DDR400 2T but single sided chip @ DDR400 1T. Maybe that is what they were getting at with the single sided/double sided thing.
It should work with 4 sticks, though you will only run at a command rate of DDR400 2T - I doubt that will make much difference to you though as you purely need RAM and not uber performance.
