1st build help please
23 Oct 2009
Hello people this is my 1st post and going to be my 1st go at building a gaming pc, i have around £700 to play with for the tower
Is the spec below gonna be any good for gaming or do you ppl in the know think i should change any of the following parts:
*OVERCLOCKED* AMD Phenom II X2 Dual Core 550 3.10GHz @ 3.60GHz / Gigabyte GA-MA770T-UD3P Motherboard / Corsair Dominator 4GB DDR3 XMS3 PC2-1600C9 (2x2GB) Bundle £269.99
HIS ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card £128.00
Coolermaster Storm 'Scout' Gaming Case - (No PSU) £79.99
Corsair VX 550W ATX Power Supply (CMPSU-550VXUK) £68.99
OcUK Brushed Aluminium Blu-Ray ROM Slot Loading Drive - Black £53.99
Samsung EcoGreen F2 1TB SATA-II 32MB Cache - OEM (HD103SI) £55.98
Microsoft Windows 7 Home Premium - Retail (Full Version) £75.99
Total comes to: £732.93
Any advice would be great and thanks in advance.
Gareth
I think you should change the following parts:
for a
Pioneer DVR-S18L 22x DVD±RW SATA Dual Layer Labelflash ReWriter - Black £20.99
for a
Point Of View GeForce GTX 260 Premium Exo 896MB GDDR3 PCI-Express Graphics Card £139.99
for a
+1 Yes.
for a
Not sure about this, The 260 is quite old now, I would have gone with a 4890 at that prioce.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-101-PC
I'd dump the eco green, it's dog slow.
WD Caviar Black, Samsung F3, Hitachi would be better choices.
You may as well buy the bundle parts separately and save £20. The multiplier is unlocked on 550 so OC to 3.6 is very simple. Mine runs at 3.5 without any increase in voltage, using stock cooler..
thanks for the replys guys suggestions taken on board,
Will change the hard drive and get the bundle parts seperate. is the 4890 best card for the under £150 price range.
Wont i need the Blu Ray drive if i want to watch Blu Rays on the pc?
Many Thanks
You will need a Blu-ray drive if you want to watch Blu-ray's on it, but buying one right now is so expensive it's not really worth it.
Having a stack of Blu-Ray films is somewhat pointless if he can't play them...
Assuming of course he has any BR films at all and doesn't have any other means of playing them :)
