- 8 Jan 2011
- Barrow in Furness
hi all new to the forums n read a few other threads about builds so i thought id ask as ive never actualy build a rig before (i like to think i know enough about pc's + ive fiddled with the insides of my own swapping psu's n gpu's hd's n the like)
so anyways im planning a new build im saving up for (gunna build myself this time as its cheaper + you know exactly what hardwares inside) and wanted some advice/it checking to make sure it will work together (ram confuses me)
so far ive picked out
phenom 2 x4 955 125w edition
http://www.overclockers.co.uk/showproduct.php?prodid=CP-244-AM
Gigabyte GA-890GPA-UD3H AMD 890GX
http://www.overclockers.co.uk/showproduct.php?prodid=MB-251-GI
Corsair TX 850W ATX SLI Compliant Power Supply
http://www.overclockers.co.uk/showproduct.php?prodid=CA-013-CS
Corsair XMS3 4GB (2x2GB) DDR3 PC3-10666C8 1333MHz Dual-Channel
http://www.overclockers.co.uk/showproduct.php?prodid=MY-257-CS
Western Digital Caviar Blue 500GB SATA-II 16MB Cache
http://www.overclockers.co.uk/showproduct.php?prodid=HD-120-WD
Arctic Cooling Freezer 7 Pro Rev 2
http://www.overclockers.co.uk/showproduct.php?prodid=HS-035-AR
with win7 64bit home premium
would these work? ill be using it for gaming 3-4 eve online clients,fps's preferably max settings, music production n such
i already have a antec 900 case and a 1tb hd ill be using for storing music/videos https://www.overclockers.co.uk/showproduct.php?prodid=HD-324-WD
to begin with ill be using an old 9800GT i have until i save up the extra for a new gpu, i was thinking http://www.overclockers.co.uk/showproduct.php?prodid=GX-147-XF or am i better going with 2 cards in crossfire? also will these cards fit in the case i have? ill be gaming on a 22" widescreen LCD but i also have a 20" widescreen LCD i use as a 2nd monitor for web browsing n such
im also unsure on the cpu cooler as ive heard it hangs over 2 ram slots which eventualy id want to add in another 2x2g sticks is there another cooler youd recomend? preferably not to expensive also im not fond of applying thermal paste so preferably one with it pre-applied
i may try out OC'ing aswel as i heard you can get those cpu's to 3.8 on air is the freezer 7 pro rev 2 good enough to cool it down at 3.8ghz?
all that comes to £760 if refeable id want it cheaper if someone can suggest a system that does the same but cheaper
anyways seen how good you guys are so thought id make as thread for you to do your magic
