I just noticed something: You're using a re-baffled sump? Is it still the wet sump as per the bike? Back when we used the CBR (And now with the Aprilla) we had to switch to a dry sump to avoid oil starvation during cornering.
Well you are doing better than some welsh uni at this. That one has yet to turn up at our place in a state in which it can be power tested / run / tuned.
It usually shows up ready be run and tested... it just breaks.... quickly
Yes Corsa Italiana I'm looking at you
That would be usIt usually shows up ready be run and tested... it just breaks.... quickly
Moral of the story is never buy "rebuilt" Aprillia engines when you can't see the bikes they came fromYes Corsa Italiana I'm looking at you
I don't think the heat was taken into account in the design, and the ceramic coating on the exhaust should have kept the heat in anyway, but clearly didn't
Just need to bed the brakes in properly and/or make them stop better, secure the clutch cable better and we'll be back there on Thursday
but if you jump start it it runs perfectly and starts easier than when it was on the Start and Charge
I wouldn't go that far
One of the main problems was that it never ran enough for the alternator to recharge the battery so we've knackered a series of batteries trying to start it, but now we're doing longer runs that seems to allow time to recharge![]()
Just found this:
That's some sweet bodywork.
We have all the parts for 8 new wishbones now, the lower ball joints are spherical bearings. We've tested a couple of times since the crash and we're consistently bending rear lower roses. Welding the new ones up tomorrow.
Also; we all hate Percy, when we're done we're going to burn him. Our headrest now looks a lot more like yours, position I mean.
it must be twice the height off the deck of the cars we had before he grew fat
Ah, yes, we have a plan regarding that. There will be new uprights designed to take larger rose joints (3/8 imperial instead of M8, I think) with no threads exposed. The inner end of the wishbones will point the roses directly at the chassis, so they can do the camber adjust. The wishbones will also be made to a finer tolerance, the current ones are rubbish.
How else do you plan on testing an impact attenuator?
My Dad was planning on judging the design section this year too, but other things have come up, so I'm not sure what's going on there
As for the templates, have you noticed how giant our car isit must be twice the height off the deck of the cars we had before he grew fat
