Hi peeps,
Just wondered if i could get some help before i throw this out the window!.
I have removed my motherboard from the case and placed it on the antistatic bag that you get with the motherboard and i am still having the same problem (fans spin up for a second then go off) the system will eventually start but you have to keep switching the PSU on/off switch, wait 10 seconds and then try the on button on the case, numerous amounts of times, happens from cold and hot.
I have tried the PSU test (short green & black wire) and it spins up fine, reseated my CPU cooler many times and it still does it, i think im just going to leave it on all the time!.
Onto my 2nd question, I built a friend of mine the same system, i think the Motherboard is DOA though, i get the same thing, fans spin up for a second then go off, but it has never booted up, i have tried the Scythe Cooler and the standard AMD cooler, done the PSU test (green/black wire shorted) tried motherboard in the case and out, tried removing the CMOS/resetting it, i have had it where its just the PSU, Motherboard, CPU and cooler and still nothing, the thing is though, i tried the 2nd PSU on my system and it does the same thing!, with my PSU my system will eventually boot tho, ive tried the new PSU loads of times. Im going to RMA the motherboard and the PSU, unless anyone has any suggestions!
Cheers
Nick
