1T and 2T
4 Sep 2005
London
Morning
I'm having trouble running Flash related apps. I can't install it basically. But when it does install. Anything i run related to flash crashs my PC. So that means no google video and no youtube.
I've been told it's a common problem running in 1T. So my question to you folks is whats the catch with running back at 2T? My ram is Kingston Value if that makes any difference.
Its hard to say without seeing your components listed in a sig, but there are a few factors to take into account here. To run with stability at 1t you usually need: to not be running 4 sticks of ram, a high quality motherboard, high quality memory, the latest bios and a little luck. ;)
The only catch with running at 2t is a slight loss of performance.
Hmm ok. My specs are;
A64 3700 @ 2.7
Asrock 939 Dualsata2 (latest bios)
1024mb Kingston value PC3200 (2x 512)
So what kind of performance decrease are we talking about here? Is it hugely noticeable?
there is a big difference in memory bandwidth going from 1t to 2t.
its a bigger difference that running ram at 2-2-2-5 to 3-3-3-10.
pointless having fast ram if you can;t run it at 1t command rate. best to do all you can to see if you can make it work at 1t.
benjo said:
Thats what i wanted to hear!
*goes off changing back to 2T*
1T - 2T gives you a 2-3% hit in gaming performance, nothing huge but its there.
As said, your mobo isn't a big fan of running 1T anyway, so you'll be happy at 2T.
2.8 is nice just from stocvk voltage the 1T works fine on my asrock, but I guess I have cheaper crucial ram :p
1T dropped 3/4 seconds off my super pi
hey benjo your overclock is not too shabby. try and push higher like me, you may be able to get to 2.9ghz at below stock volts :D wish this board allowed for a higher htt im sure i could take this cpu over 3ghz.
Well i tried 2.9 but it froze :(
So i put the ram on a 133 divider to make sure it wasnt the ram overclocking too much but there was an error. So 2.87 is the max it can take on stock volts :) Really tempted to do the vcore mod, but i think 2.8 is fine for now :)
stock volts? why do you need to to a vmod? stock voltage for that cpu is 1.4v you can take the voltage on the asrock board up to 1.45v. that shoudl be more than enough to allow you to get a higher overclock. i would prefer not to go over 1.45v that way temps still stay low.
odd, for me and all the other people i know the stock voltage is 1.40v and it shows in the bios the max available vcore to be 1.45v.
you sure your not mistaking the max vcore limit number for your actual vcore amount?
what does cpuz say?
