1TB hard drive only showing 346MB
17 Aug 2011
Okay, first and foremost, thank you overclockers for helping me decide on my first build and helping with advice, i got my comp, built it and everything is good, except 1 problem.
I have an SSD as my C:, however i also have a 1TB seagate hard drive for storage etc., however, as the title says, my computer is saying "this only has a limit of 346MB" which i know 1TB advertised might not be exact, but that seems a little too low to me as i have nearly nothing saved on it and i've already used a 3rd of the memory already. (i have 287MB free apparently)
Please ask for any information you need, i don't know if it's a mistake from where i installed it or from the software. OS windows 8.1, HD Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache.
Screenshot of the drive from administrative tools->computer management->storage->disc management could be useful. (Or use windows key + r and enter diskmgmt.msc).
You need to format e drive to ntfs,that will give you the rest of the space on your drive,if it is brand new they normally need formatting.
Right click in the blue area of drive E and delete that partition, the whole lot will then turn black, the right click in the whole black area and create a new simple volume, follow the instructions, format to NTFS, leave everything else at defaults.
ps. if you create a new volume now out of whats left now, ie the black area, it will create yet another drive, so half will be drive E and the other part would be drive F for instance, I take it you want it all as one, which is why you need to delete the existing partition first.
thanks for the help, i am new to all this. It wont let me delete the part that is already formatted, I dont get why part of it is already formatted :S
looks like windows has claimed some of drive e: for system files, hence why you cannot delete the partition.
usually you wouldn't see a system partition, so i'm not sure why its got a drive letter. unless you want to re-install windows i'd just format the unallocated space and ignore that 350mb partition.
i gave it a drive letter when i was trying to access it, I've now removed the drive letter and formatted the remaining 900+GB and given that a letter, thanks for the help people.
I still have 930GB, which is 93% of the drive, not gonna cry over 7%.
Finally, my new computer is fully built, fully functioning and fully in use, so happy :D (Though it's so quiet, i keep having to take off my headset to check if i can hear the fans running, even then i have to strain my ears)
