16 May 2018 at 16:36 #1 Ga12thr Ga12thr Associate Joined 11 Jan 2018 Posts 6 How can run dual screen using a gtx 1060 which has 1x hdmi 1x Dp and 2x dvi ports but the monitors only have hdmi and vga? Please help ?
17 May 2018 at 01:56 #2 LuckyBenski LuckyBenski Soldato Joined 28 Dec 2017 Posts 10,146 Location Beds DisplayPort to HDMI cable, it's a passive cable as they share many signal wires.
18 May 2018 at 12:36 #3 t31os t31os Soldato Joined 24 May 2006 Posts 3,824 Location Surrey - UK Or DVI to HDMI, you sometimes get them GPUs. Then you can just use two of the numerous HDMI cables you likely have floating around.
