i thought it was master on the end slave in the middle and also if you change 1 from cable select ull need to change the other, but if they are both on cable select itll be fine
I bought a few akasa rounded 80pin ribbon cables and they both had pull tabs with "slave" in the middle and "master" at the end written on them. Dont see why the master would be furthest away? I just used the jumpers to set them to master/slave and had master closest to the mobo..
