- 29 Aug 2010
- Cornwall
Hi,
I've got a 1440p monitor (144Hz) and UHD monitor (60Hz).
I'd like to connect 2 both monitors to a 290x, well, 290X Crossfire if that makes a difference but I think you can only connect to the top card.
Both monitors need DisplayPort 1.2 but the 290X only has a single DisplayPort.
Is there any way I can do this? Like a dual DVI to DP adaptor or something?
AMDMatt suggested connecting one monitor to each card, but I tried this and it didn't work, only the top monitor showed up.
And he suggested a MST (?) adaptor, but later confirmed they split the signal and 50% of a DisplayPort 1.2 signal isn't enough for either.
So is there anything I can do?
With the higher resolutions and DX12 incoming I'm wondering if the 290X Crossfire setup might be better than my 980 SLI setup going forward.
