- 30 Aug 2014
I got 2 PCs, one running DP and one running HDMI to the same monitor (LG 34UM95).
Peripherals are: Corsair k95 platinum (2x USB cable) & Logitech G502 Lightspeed Wireless with dongle.
What's the best way to switch PCs with this monitor without unplugging any cables at the back of each PC?
The monitor has: 3x USB inputs, 1x USB Up (which needs to be connected to the PC for the peripherals to work).
I was thinking of getting a USB Up splitter like this then running 1 cable from each PC into the splitter, whilst having the corsair and logitech connected to the 3x USB inputs in the monitor.
Would this work?
Then all I gotta do it switch between DP/HDMI depending on which PC is on.
Not sure what would happen if both PCs on at once, which one would the peripherals work with
Would this work?
